ptd0647 Posted September 23, 2005 Share Posted September 23, 2005 I just get the timing belt and water pump replaced on my 99 LS400 from a local mechanic (not Lexus dealer) and now the VSC light stay on. Does any body know how to turn it off or know what the cause for VSC light to stay on? Thanks. Paul Quote Link to comment Share on other sites More sharing options...
sha4000 Posted September 23, 2005 Share Posted September 23, 2005 I just get the timing belt and water pump replaced on my 99 LS400 from a local mechanic (not Lexus dealer) and now the VSC light stay on. Does any body know how to turn it off or know what the cause for VSC light to stay on?Thanks. Paul ← when was the work done and how long has the vsc been on?on my 98 whenever you disconnect anything under the hood and plug it back up the vsc light comes on but after a few start ups and driving it usually goes off. dont worry almost anything can make that light come on Quote Link to comment Share on other sites More sharing options...
GRAND_LS 4 Posted September 23, 2005 Share Posted September 23, 2005 I just get the timing belt and water pump replaced on my 99 LS400 from a local mechanic (not Lexus dealer) and now the VSC light stay on. Does any body know how to turn it off or know what the cause for VSC light to stay on?Thanks. Paul ← when was the work done and how long has the vsc been on?on my 98 whenever you disconnect anything under the hood and plug it back up the vsc light comes on but after a few start ups and driving it usually goes off. dont worry almost anything can make that light come on ← Right. I've found out that if you unplug pretty much anything under the hood, the VSC light comes on, even brake fluid reservoir sensor. Just double, and triple check for unplugged harnesses. Quote Link to comment Share on other sites More sharing options...
ptd0647 Posted September 26, 2005 Author Share Posted September 26, 2005 I just get the timing belt and water pump replaced on my 99 LS400 from a local mechanic (not Lexus dealer) and now the VSC light stay on. Does any body know how to turn it off or know what the cause for VSC light to stay on?Thanks. Paul ← when was the work done and how long has the vsc been on?on my 98 whenever you disconnect anything under the hood and plug it back up the vsc light comes on but after a few start ups and driving it usually goes off. dont worry almost anything can make that light come on ← Right. I've found out that if you unplug pretty much anything under the hood, the VSC light comes on, even brake fluid reservoir sensor. Just double, and triple check for unplugged harnesses. Thank you guys. I found a section in the owner manual that describe how to reset the VSC light. ← Quote Link to comment Share on other sites More sharing options...
Lexus Itch Posted January 4, 2006 Share Posted January 4, 2006 my VSC was on when the battery is bad. It was hard to start too. I changed the new battery and no more problem. Quote Link to comment Share on other sites More sharing options...
