Hmmmm My post got ate up!
Drive around the block until the coolant comes up to the normal temp range.
Bridge E1 & TE1 in a DIAGNOSTIC port.
Connect the ground of the light
The inductive pick-up to the #1 spark plug wire
Power wire
When you point the light at the timing guide, it should rear 10*btdc @ idle.
The engine itself is very de-tuned.
You can try retarding to 7*btdc, or advancing to 17*btdc in a quest for better throttle responce, and a few hoursepower.
Even at 7* of base advance (17*btdc) you shouldn't have to run anything more than 87 pump gas.
