Silverback Posted September 13, 2005 Share Posted September 13, 2005 I have a 2001 GS300 and the trunk lid will never stays up on it's own...grrrr Anyone know how to adjust it, or have instructions on what needs to be replaced and how? Thanks Quote Link to comment Share on other sites More sharing options...
knmaynard Posted September 13, 2005 Share Posted September 13, 2005 Same model year, same problem. I need the same instructions . . . Quote Link to comment Share on other sites More sharing options...
joey8675 Posted September 13, 2005 Share Posted September 13, 2005 Go to home depot, to the section where they sell the poles. Get one cut to the size of your trunk, use it to prop the trunk open. :D :D :D Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted September 14, 2005 Share Posted September 14, 2005 Better solution. Order two torsion bars, the bars the criss cross each other under the rear shelf (inside the trunk.) There are two kinds, the standard and the version for trunk lids with a spoiler. The difference is the latter is heavier. If you really want the trunk to fly up and stay up, get the heavier bars. Look here. 10 and 11 in the image attached. Quote Link to comment Share on other sites More sharing options...
Neo Posted September 14, 2005 Share Posted September 14, 2005 One thing you can try before getting the spoiler version is to change the setting of the ones in your car. There are 3 notches at the end that you can position them. I cannot remember which direction is stiffer but it is easy trial and error. Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted September 14, 2005 Share Posted September 14, 2005 One thing you can try before getting the spoiler version is to change the setting of the ones in your car. There are 3 notches at the end that you can position them. I cannot remember which direction is stiffer but it is easy trial and error. ← There are no notches in my '98. The last time I saw notches was in a GM . In some other designs, the load on the rod is affected (as you suggested) by moving right-angled bent end of the rod to another notch to change the twist on the rod. Quote Link to comment Share on other sites More sharing options...
Neo Posted September 14, 2005 Share Posted September 14, 2005 One thing you can try before getting the spoiler version is to change the setting of the ones in your car. There are 3 notches at the end that you can position them. I cannot remember which direction is stiffer but it is easy trial and error. ← There are no notches in my '98. The last time I saw notches was in a GM . In some other designs, the load on the rod is affected (as you suggested) by moving right-angled bent end of the rod to another notch to change the twist on the rod. ← There are on mine. Here is a pic someone I know put up. When I put on my aftermarket spoiler, I tried this but it was not enough. I had to but the stiffer bars. If the original poster does not have a spoiler, this may be enough. Quote Link to comment Share on other sites More sharing options...
Silverback Posted September 14, 2005 Author Share Posted September 14, 2005 There are on mine. Here is a pic someone I know put up. When I put on my aftermarket spoiler, I tried this but it was not enough. I had to but the stiffer bars. If the original poster does not have a spoiler, this may be enough. ← Thanks for the feedback, the pictures and the notch approach has worked for the moment. But as mentioned above, I too will be adding a spoiler and I know this will not bridge the weight gap. Eitherway, once again excellent feedback group Cheers Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted September 15, 2005 Share Posted September 15, 2005 ***Update*** There are notches in my '98. I should have looked furthur. I guess it's a good time to replace the burned out lamp in the trunk. <_< Quote Link to comment Share on other sites More sharing options...
RicoPerez Posted May 9, 2016 Share Posted May 9, 2016 I am intending to buy the torsion bars to replace the old ones. Does anybody know the part number/s and where to buy them for less? Thanks. Quote Link to comment Share on other sites More sharing options...
bullhog Posted December 20, 2016 Share Posted December 20, 2016 Rick, did you ever replace your original torsion bars? For 2003 Lexus GS300 The part numbers for anyone that needs them: #11 Rear Left w/spoiler 6453230260 #10 Rear Right w/spoiler 6453130260 Please confirm part #'s with dealer for any changes, Rob Quote Link to comment Share on other sites More sharing options...
RicoPerez Posted December 21, 2016 Share Posted December 21, 2016 Thank you for these part numbers. I did not yet buy this part because I moved the torsion bars nearer to the trunk. So far, it is working. Quote Link to comment Share on other sites More sharing options...
