security_guy Posted September 13, 2005 Posted September 13, 2005 Does anyone know if the NAV DVD can be successfully copied and used in another LC or LX if it is placed in the same type system?
madkow70 Posted September 29, 2005 Posted September 29, 2005 Does anyone know if the NAV DVD can be successfully copied and used in another LC or LX if it is placed in the same type system? ← i copied my data to a DVD-RW. my Nav could not read it. (no problem from my computer). same failure on DVD+RW format as well.
GlennR Posted October 11, 2005 Posted October 11, 2005 The Nav DVD is dual sided - if you have that type of DVD burner, you should be able to duplicate an original.
navguy Posted October 17, 2005 Posted October 17, 2005 The Nav DVD is dual sided - if you have that type of DVD burner, you should be able to duplicate an original. ← The DVD map disc is is not dual-sided or dual-layered. If it were the capacity would be much greater than the 4.7gigabyes.
