heejinp Posted September 8, 2005 Share Posted September 8, 2005 Thanx to Toysrme...I have an excellent picture of the location to replace the 1998 ES300 cabin carbon filter but the white plastic slot piece does not seem to want to come out? and the second problem is that the replacement carbon filter box comes with two filters which don't look it each other...so after taking to the pastic piece out...which filter goes first and which way does it go...thanx in advance for all the help. Quote Link to comment Share on other sites More sharing options...
camlex Posted September 8, 2005 Share Posted September 8, 2005 Hope this helps, http://us.lexusownersclub.com/forums/index...opic=17736&st=0 Quote Link to comment Share on other sites More sharing options...
mburnickas Posted September 8, 2005 Share Posted September 8, 2005 Thanx to Toysrme...I have an excellent picture of the location to replace the 1998 ES300 cabin carbon filter but the white plastic slot piece does not seem to want to come out? and the second problem is that the replacement carbon filter box comes with two filters which don't look it each other...so after taking to the pastic piece out...which filter goes first and which way does it go...thanx in advance for all the help. ← there are 2 pieces to the 1 filter. The upper and lower filter/piece. You slide the upper filter in and slide up. Then, holding the upper filter up, you slide the lower (larger) filter right in. That is how I do it on my 98.; Quote Link to comment Share on other sites More sharing options...
