Power Window Problem
paulo
I am having a problem with my front right power window. From the right door it works fine, from the drivers control it will go down but it will not go back up. The other window controls work fine from the drivers side. Does anyone know what the problem might be?
Thanks ..
yeah.  i had a similar problem when i bought mine.  just pull out the driver side switch, pry it open and clean all the contacts, paying special attention to the passenger side one.  the switch is pretty easy to get out.
Thanks for the help guys, I'll give that a try.
