95 Sc300 High Mount Brake Light
bradperk
Well funny you should ask as I had mine out tonight. Just get a flat putty knife under the front edge, near the seat, and pop it upward, then pull forward. There is a connector that with a push will seperate. As for the bulbs, I only had to fix wiring and that cured the warning light on the dash also.
Good luck,
Joel :D
What is the secret to removing the cover for the light assembly.  Once the assembly is removed is there anything tricky on the inside.
