I figured I would share this for any of the guru's out there. Most I get so I will need to pull the book for some of the odd ball things. Do not ge the, for example, LT FTRM x (long term fuel trim).
Car sitting for 3 days, in garage, since I take my bike to work.
Outside Variables:
-Outside temp 78 F
-8-18-2005
-Car data via Snap-on Microscan Scanner Took 39 “snap shots”
- I did not post all 35 here....to long...so this is a snap shot of data...neat I think.
(1 out of 35) (just started)
MIL STATUS: OFF
ABSLT TPS (%) 13.3
ENGINE (RPM) 1517
CALC LOAD (%) 25.1
MAF (LB/M): 1.49
COOLANT (F): 86
IAT (F) 79
IGN ADV (DEG) 10.5
LT FTRM1(%) –5.5
ST FTRM1(%) –5.5
LT FTRM2 (%) –3.9
ST FTRM2(%) –5.5
VEH SPEED (MPH) 0
FUEL SYS 1: CLSD
FUEL SYS 2: CLSD
O2S11(V): 0.655
STFTRM11 (%) –5.5
O2S12: 0.080
O2S21: -.655
STFTRM21(%) –7.0
(11 out of 35) (pulled out of driveway and starting to move)
MIL STATUS: OFF
ABSLT TPS (%) 16.1
ENGINE (RPM) 1343
CALC LOAD (%) 40.4
MAF (LB/M) 2.17
COOLANT (F): 109
IAT (F): 81
IGN ADV (DEG) 20.0
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
VEH SPEED (MPH): 6
FUEL SYS 1: CLSD
FUEL SYS 2: CLSD
O2S11(V): 0.665
STFTRM11 (%) –3.9
(21 out of 35) (driving down road about 1/5 mile)
MIL STATUS: OFF
ABSLT TPS (%) 18.0
ENGINE (RPM) 2124
CALC LOAD (%) 31.4
MAF (LB/M) 2.61
COOLANT (F): 124
IAT (F): 81
IGN ADV (DEG) 31.5
LT FTRM1 %) –3.1
ST FTRM1(%) –2.3
LT FTRM2 (%) –3.9
ST FTRM2(%) –9.4
VEH SPEED (MPH): 37
FUEL SYS 1: CLSD
FUEL SYS 2: CLSD
O2S11(V): 0.600
STFTRM11 (%) –20.3
O2S12: 0.865
O2S21: 0.685
STFTRM21(%) –14.8
**Any comments throw them out. I did it since of the other thread that Toysrme commented on (thanks). He got me thinking about my o2 sensors. So this was the outcome. Overboard as :D :D
Ironic, I was just talking to a solara owner having o2 problems. (16mpg)
Something very important to note is how Toyota V bank computers tune fuel. The ECU treats the different banks like different engines. Ignition, controls, it's one engine, but when it comes to fuel... Nope! Each bank get's tuned like a different engine.
Everything looks pretty good.
Well, with 2.61lb/m it's making about... 30hp.
If you just want to give me something to do, turn the cruise control on say 40mph. Type in 3/4/5 in snaps in a row. I'm curious on your o2 readings. 0.685v is a bit high for cruising around. Normally they don't go so high out of throttle transitions/open loop acceleration.
One snapshot doesn't tell a story, I'd like to see 1/2 snapshots before & after.
Man... If I had an OBD-II car, I would be big pimping the scanners that run on a palm. Those things read everything for real cheap! Eh, you get use to reading volt gauges & multi meters with OBD-I hahahahaha
**EDIT: mileage in city: 23.273 to 24.875 (via my tacking from past 3+ years. Highway is 27 to 29.XXX mpg.
VEH SPEED (MPH): 42
O2S11(V): 0.650
O2S12: 0.555
O2S21: 0.650
LT FTRM1 %) –4.7
ST FTRM1(%) –7.8
LT FTRM2 (%) –3.9
ST FTRM2(%) –0.8
ST FTRM11 (%): -3.9
ST FTRM 21 (%): –4.7
2
VEH SPEED (MPH): 42
O2S11(V): 0.655
O2S12: 0.430
O2S21: 0.660
LT FTRM1 %) –2.3
ST FTRM1(%) –5.5
LT FTRM2 (%) –2.3
ST FTRM2(%) –5.5
ST FTRM11 (%): -6.3
ST FTRM 21 (%) –5.5
3
VEH SPEED (MPH): 42
O2S11(V): 0.655
O2S12: 0.265
O2S21: 0.655
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
ST FTRM11 (%): -5.5
ST FTRM 21 (%): -5.5
4
VEH SPEED (MPH): 42
O2S11(V): 0.655
O2S12: 0.205
O2S21: 0.660
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
ST FTRM11 (%): -6.3
ST FTRM 21 (%): -4.
5
VEH SPEED (MPH): 42
O2S11(V): 0.660
O2S12: 0.160
O2S21: 0.655
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
ST FTRM11 (%): -3.9
ST FTRM 21 (%):-4.7
6
VEH SPEED (MPH): 42
O2S11(V): 0.655
O2S12: 0.160
O2S21: 0.650
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
ST FTRM11 (%): -3.9
ST FTRM 21 (%): -4.7
7
VEH SPEED (MPH): 42
O2S11(V): 0.655
O2S12: 0.150
O2S21: 0.650
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
ST FTRM11 (%): -3.1
ST FTRM 21 (%):-4.7
8
VEH SPEED (MPH): 42
O2S11(V): 0.655
O2S12: 0.160
O2S21: 0.650
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
ST FTRM11 (%): -2.3
ST FTRM 21 (%): -3.1
9
VEH SPEED (MPH): 42
O2S11(V): 0.655
O2S12: 0.160
O2S21: 0.650
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
ST FTRM11 (%): -2.3
10
VEH SPEED (MPH): 42
O2S11(V): 0.655
O2S12: 0.155
O2S21: 0.650
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
ST FTRM11 (%): -2.3
ST FTRM (%) 21: -3.9
11
VEH SPEED (MPH): 42
O2S11(V): 0.655
O2S12: 0.175
O2S21: 0.655
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
ST FTRM11 (%): -3.9
ST FTRM 21 (%): -3.96
12
VEH SPEED (MPH): 42
O2S11(V): 0.655
O2S12: 0.190
O2S21: 0.650
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
ST FTRM11 (%): -2.3
13
VEH SPEED (MPH): 42
O2S11(V): 0.650
O2S12: 0.230
O2S21: 0.650
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
ST FTRM11 (%): -2.3
ST FTRM 21 (%) : -3.9
14
VEH SPEED (MPH): 42
O2S11(V): 0.640
O2S12: 0.325
O2S21: 0.660
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
ST FTRM11 (%): -4.7
15
VEH SPEED (MPH): 42
O2S11(V): 0.655
O2S12: 0.355
O2S21: 0.645
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
ST FTRM11 (%): -1.6
16
VEH SPEED (MPH): 42
O2S11(V): 0.650
O2S12: 0.535
O2S21: 0.650
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
ST FTRM11 (%): -3.1
ST FTRM 21 (%) : -4.7
17
VEH SPEED (MPH): 42
O2S11(V): 0.655
O2S12: 0.675
O2S21: 0.655
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
ST FTRM11 (%): -3.1
18
VEH SPEED (MPH): 42
O2S11(V): 0.655
O2S12: 0.685
O2S21: 0.655
LT FTRM1 %) –5.5
ST FTRM1(%) –4.7
LT FTRM2 (%) –3.1
ST FTRM2(%) –6.3
ST FTRM11 (%): -1.6
ST FTRM 21 (%):-3.9
Looks good. I would expect it to use a little lessfuel crusing around, but that's still damn good mileage.
Any idea which O2ID goes to what location? Example, O2S11 in the font, back or by the cat..
O2S11(V): 0.650 - bank 1, sensor 1 (rear bank)
O2S12: 0.555 - bank 1, sensor 2 (post-cat)
O2S21: 0.650 - bank 2, sensor 1 (front bank)
