mburnickas Posted August 18, 2005 Posted August 18, 2005 I figured I would share this for any of the guru's out there. Most I get so I will need to pull the book for some of the odd ball things. Do not ge the, for example, LT FTRM x (long term fuel trim). Car sitting for 3 days, in garage, since I take my bike to work. Outside Variables: -Outside temp 78 F -8-18-2005 -Car data via Snap-on Microscan Scanner Took 39 “snap shots” - I did not post all 35 here....to long...so this is a snap shot of data...neat I think. (1 out of 35) (just started) MIL STATUS: OFF ABSLT TPS (%) 13.3 ENGINE (RPM) 1517 CALC LOAD (%) 25.1 MAF (LB/M): 1.49 COOLANT (F): 86 IAT (F) 79 IGN ADV (DEG) 10.5 LT FTRM1(%) –5.5 ST FTRM1(%) –5.5 LT FTRM2 (%) –3.9 ST FTRM2(%) –5.5 VEH SPEED (MPH) 0 FUEL SYS 1: CLSD FUEL SYS 2: CLSD O2S11(V): 0.655 STFTRM11 (%) –5.5 O2S12: 0.080 O2S21: -.655 STFTRM21(%) –7.0 (11 out of 35) (pulled out of driveway and starting to move) MIL STATUS: OFF ABSLT TPS (%) 16.1 ENGINE (RPM) 1343 CALC LOAD (%) 40.4 MAF (LB/M) 2.17 COOLANT (F): 109 IAT (F): 81 IGN ADV (DEG) 20.0 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 VEH SPEED (MPH): 6 FUEL SYS 1: CLSD FUEL SYS 2: CLSD O2S11(V): 0.665 STFTRM11 (%) –3.9 (21 out of 35) (driving down road about 1/5 mile) MIL STATUS: OFF ABSLT TPS (%) 18.0 ENGINE (RPM) 2124 CALC LOAD (%) 31.4 MAF (LB/M) 2.61 COOLANT (F): 124 IAT (F): 81 IGN ADV (DEG) 31.5 LT FTRM1 %) –3.1 ST FTRM1(%) –2.3 LT FTRM2 (%) –3.9 ST FTRM2(%) –9.4 VEH SPEED (MPH): 37 FUEL SYS 1: CLSD FUEL SYS 2: CLSD O2S11(V): 0.600 STFTRM11 (%) –20.3 O2S12: 0.865 O2S21: 0.685 STFTRM21(%) –14.8 **Any comments throw them out. I did it since of the other thread that Toysrme commented on (thanks). He got me thinking about my o2 sensors. So this was the outcome. Overboard as :D :D
Toysrme Posted August 19, 2005 Posted August 19, 2005 Ironic, I was just talking to a solara owner having o2 problems. (16mpg) Something very important to note is how Toyota V bank computers tune fuel. The ECU treats the different banks like different engines. Ignition, controls, it's one engine, but when it comes to fuel... Nope! Each bank get's tuned like a different engine. (21 out of 35) (driving down road about 1/5 mile) Everything looks pretty good. Well, with 2.61lb/m it's making about... 30hp. If you just want to give me something to do, turn the cruise control on say 40mph. Type in 3/4/5 in snaps in a row. I'm curious on your o2 readings. 0.685v is a bit high for cruising around. Normally they don't go so high out of throttle transitions/open loop acceleration. One snapshot doesn't tell a story, I'd like to see 1/2 snapshots before & after. Man... If I had an OBD-II car, I would be big pimping the scanners that run on a palm. Those things read everything for real cheap! Eh, you get use to reading volt gauges & multi meters with OBD-I hahahahaha
Toysrme Posted August 19, 2005 Posted August 19, 2005 I wanna know how hot the CTS thinks the coolant is too, that's funny! =)
mburnickas Posted August 19, 2005 Author Posted August 19, 2005 If you just want to give me something to do, turn the cruise control on say 40mph. Type in 3/4/5 in snaps in a row. I'm curious on your o2 readings. 0.685v is a bit high for cruising around. Normally they don't go so high out of throttle transitions/open loop acceleration.One snapshot doesn't tell a story, I'd like to see 1/2 snapshots before & after. ← **EDIT: mileage in city: 23.273 to 24.875 (via my tacking from past 3+ years. Highway is 27 to 29.XXX mpg. 1 VEH SPEED (MPH): 42 O2S11(V): 0.650 O2S12: 0.555 O2S21: 0.650 LT FTRM1 %) –4.7 ST FTRM1(%) –7.8 LT FTRM2 (%) –3.9 ST FTRM2(%) –0.8 ST FTRM11 (%): -3.9 ST FTRM 21 (%): –4.7 2 VEH SPEED (MPH): 42 O2S11(V): 0.655 O2S12: 0.430 O2S21: 0.660 LT FTRM1 %) –2.3 ST FTRM1(%) –5.5 LT FTRM2 (%) –2.3 ST FTRM2(%) –5.5 ST FTRM11 (%): -6.3 ST FTRM 21 (%) –5.5 3 VEH SPEED (MPH): 42 O2S11(V): 0.655 O2S12: 0.265 O2S21: 0.655 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 ST FTRM11 (%): -5.5 ST FTRM 21 (%): -5.5 4 VEH SPEED (MPH): 42 O2S11(V): 0.655 O2S12: 0.205 O2S21: 0.660 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 ST FTRM11 (%): -6.3 ST FTRM 21 (%): -4. 5 VEH SPEED (MPH): 42 O2S11(V): 0.660 O2S12: 0.160 O2S21: 0.655 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 ST FTRM11 (%): -3.9 ST FTRM 21 (%):-4.7 6 VEH SPEED (MPH): 42 O2S11(V): 0.655 O2S12: 0.160 O2S21: 0.650 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 ST FTRM11 (%): -3.9 ST FTRM 21 (%): -4.7 7 VEH SPEED (MPH): 42 O2S11(V): 0.655 O2S12: 0.150 O2S21: 0.650 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 ST FTRM11 (%): -3.1 ST FTRM 21 (%):-4.7 8 VEH SPEED (MPH): 42 O2S11(V): 0.655 O2S12: 0.160 O2S21: 0.650 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 ST FTRM11 (%): -2.3 ST FTRM 21 (%): -3.1 9 VEH SPEED (MPH): 42 O2S11(V): 0.655 O2S12: 0.160 O2S21: 0.650 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 ST FTRM11 (%): -2.3 ST FTRM 21 (%): -3.1 10 VEH SPEED (MPH): 42 O2S11(V): 0.655 O2S12: 0.155 O2S21: 0.650 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 ST FTRM11 (%): -2.3 ST FTRM (%) 21: -3.9 11 VEH SPEED (MPH): 42 O2S11(V): 0.655 O2S12: 0.175 O2S21: 0.655 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 ST FTRM11 (%): -3.9 ST FTRM 21 (%): -3.96 12 VEH SPEED (MPH): 42 O2S11(V): 0.655 O2S12: 0.190 O2S21: 0.650 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 ST FTRM11 (%): -2.3 ST FTRM 21 (%): -3.9 13 VEH SPEED (MPH): 42 O2S11(V): 0.650 O2S12: 0.230 O2S21: 0.650 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 ST FTRM11 (%): -2.3 ST FTRM 21 (%) : -3.9 14 VEH SPEED (MPH): 42 O2S11(V): 0.640 O2S12: 0.325 O2S21: 0.660 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 ST FTRM11 (%): -4.7 ST FTRM 21 (%): -3.9 15 VEH SPEED (MPH): 42 O2S11(V): 0.655 O2S12: 0.355 O2S21: 0.645 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 ST FTRM11 (%): -1.6 ST FTRM 21 (%): -3.1 16 VEH SPEED (MPH): 42 O2S11(V): 0.650 O2S12: 0.535 O2S21: 0.650 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 ST FTRM11 (%): -3.1 ST FTRM 21 (%) : -4.7 17 VEH SPEED (MPH): 42 O2S11(V): 0.655 O2S12: 0.675 O2S21: 0.655 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 ST FTRM11 (%): -3.1 ST FTRM 21 (%): -4.7 18 VEH SPEED (MPH): 42 O2S11(V): 0.655 O2S12: 0.685 O2S21: 0.655 LT FTRM1 %) –5.5 ST FTRM1(%) –4.7 LT FTRM2 (%) –3.1 ST FTRM2(%) –6.3 ST FTRM11 (%): -1.6 ST FTRM 21 (%):-3.9
Toysrme Posted August 19, 2005 Posted August 19, 2005 What kinda mileage you get? & what are the fuel trims ;)
mburnickas Posted August 19, 2005 Author Posted August 19, 2005 What kinda mileage you get?& what are the fuel trims ;) ← added info above
Toysrme Posted August 19, 2005 Posted August 19, 2005 Looks good. I would expect it to use a little lessfuel crusing around, but that's still damn good mileage.
mburnickas Posted August 19, 2005 Author Posted August 19, 2005 Looks good. I would expect it to use a little lessfuel crusing around, but that's still damn good mileage. ← Any idea which O2ID goes to what location? Example, O2S11 in the font, back or by the cat..
Toysrme Posted August 19, 2005 Posted August 19, 2005 O2S11(V): 0.650 - bank 1, sensor 1 (rear bank) O2S12: 0.555 - bank 1, sensor 2 (post-cat) O2S21: 0.650 - bank 2, sensor 1 (front bank)
