Whats my reccommended psi for my 1995 es 300. on the the tires they say maximum 44, and in the glove department where it should say the psi, its just blank. What would your reccomend?
Toyota of USA recommends 32psi all around.
Toyota of Europe recommends 38psi for highway driving in general, and speeds above 90mph.
38-40psi works the best for me. I've found the stock Goodyear Eagle's, a set of bridgestones & a cheap set of Delta tires all wear unevenly, & handle poorly at 32psi. I normally run 40 front 38 rear.
If you drag race, take a cig lighter pump to the track. Inflate the rear to 44psi, deflate the fronts to 22-25psi. That's the best drag racing combo.
The only road racing v6 Camry/ES I know uses 25psi front, 28psi rear.
I put mine between 33 - 35 psi......best pressure imo for comfort & a bit of handling. B)
:cheers:
