After 22,000 km the runflats needed replacing, I had the Pilots installed, it has been only a week but on 2 occasions when accelerating from around 160 to 190 the tire sensor has gone off and tire pressure has been found to be way down, this is in 2 different wheels, any ideas?
i am guessing the wheels replaced are not seating right and at theat speed they might be pulling of the rim or bead of the rim
are tehy the exact same tire size
245/40 18's and hat are the speed ratings of the tires?
Hi
Tire size is correct, this happened once with the run flats also coming off the #407 onto #410 onramp at about 210 k. they have never lost all the air but have dropped as low as 21 psi in a very short time when ther had been no warning light .
than for the response
Paul
