andrecat112 Posted August 5, 2005 Share Posted August 5, 2005 is it normal to hear from inside the cabin the a/c compressor running? if not what type or viscosity of oil should i buy? i saw at autozone two types, one with a viscosity of 40 and the other a viscosity of 100? thanks andrecat112 Quote Link to comment Share on other sites More sharing options...
andrecat112 Posted August 7, 2005 Author Share Posted August 7, 2005 i guess nobody elses compressor is as loud as mine....must mean its functioning normally?? Quote Link to comment Share on other sites More sharing options...
SnesleyWipes Posted August 7, 2005 Share Posted August 7, 2005 is it normal to hear from inside the cabin the a/c compressor running? if not what type or viscosity of oil should i buy? i saw at autozone two types, one with a viscosity of 40 and the other a viscosity of 100? thanks andrecat112 ← You might need new compressor or clutch. Maybe a recharge but depends on the sound. Quote Link to comment Share on other sites More sharing options...
m sorel Posted August 7, 2005 Share Posted August 7, 2005 my compressor was whining a ton too, I think it was caused by low refrigerant/oil as my pressure switch has now turned off my ac permanently tough to say as a bearing can whine as well I suggest checking the low side pressure (easy to do), If it is in the right range I doubt your oil magically escaped out of the system. Does you compressor cycle quickly i.e. every 5 seconds, mine did that too. Quote Link to comment Share on other sites More sharing options...
andrecat112 Posted August 7, 2005 Author Share Posted August 7, 2005 my compressor was whining a ton too, I think it was caused by low refrigerant/oil as my pressure switch has now turned off my ac permanentlytough to say as a bearing can whine as well I suggest checking the low side pressure (easy to do), If it is in the right range I doubt your oil magically escaped out of the system. Does you compressor cycle quickly i.e. every 5 seconds, mine did that too. ← last time i checked the freon level was good. does this mean the oil level is good also? i dont think it cycles every 5 seconds (maybe when im sitting in rush hour traffic + hot temps), but ill double check to see. i do notice the "clicking" sound when the compressor engages. andrecat Quote Link to comment Share on other sites More sharing options...
