Low Coolant Light On When Antifreeeze Is Full
landrover
I have a 92 ls400, two days ago the low coolant light came on. It didn't need much, maybe a 1/2 cup. The light went off. The next day the light is on again, coolant level is fine and the light is still on. Any help? Thanks.
Hello.. I had a similar occurance. My light stayed off when I added fluid.
I dont know exact specs on transmitter, but tap is lightly and maybe this will knock some sense into it!
Actually check out the wires (I think they have a sealent over it) then make sure it is full again.. Tap on it a bit.. If light stays on and it bothers you then you may have to replace.
