onovtec Posted July 19, 2005 Share Posted July 19, 2005 I just purchased a 2001 LS430 (Ultra Premium) in Canada. This model does not have navigation. I can't get the compass to display the direction in the center of the guage cluster. I believe that the button disp2 (steering wheel) is supposed to switch between the outside temp and compass, I get the temperature, then I keep the button pressed for (1-2) seconds as per the manual, the temp disappears, but no compass shows up. Is it broken? Has anyone had to get it fixed. Thanks Quote Link to comment Share on other sites More sharing options...
Aficionado95 Posted September 30, 2009 Share Posted September 30, 2009 I just purchased a 2001 LS430 (Ultra Premium) in Canada. This model does not have navigation. I can't get the compass to display the direction in the center of the guage cluster. I believe that the button disp2 (steering wheel) is supposed to switch between the outside temp and compass, I get the temperature, then I keep the button pressed for (1-2) seconds as per the manual, the temp disappears, but no compass shows up. Is it broken? Has anyone had to get it fixed.Thanks Have you found the solution? Im having the same problem. Quote Link to comment Share on other sites More sharing options...
SW03ES Posted October 1, 2009 Share Posted October 1, 2009 Don't hold the button down...just press it. Quote Link to comment Share on other sites More sharing options...
mgcho Posted March 19, 2010 Share Posted March 19, 2010 You press it till temperature display is disappeared. Then press reset button below and do press disp 2 button again. You will get the compass back! :P Quote Link to comment Share on other sites More sharing options...
