al010101 Posted July 14, 2005 Posted July 14, 2005 sorry if this is a dumb question, i looked around and couldn't find, where is the IAC located? i assume it's the longer round solenoid on the throttle body (right one)? my car randomly runs horribly, doesn't idle, stalls, will idle very horribly, then suddenly will just act like nothing happen, then randomly will happen again...
2XLexV8 Posted July 28, 2005 Posted July 28, 2005 sorry if this is a dumb question, i looked around and couldn't find, where is the IAC located? i assume it's the longer round solenoid on the throttle body (right one)? my car randomly runs horribly, doesn't idle, stalls, will idle very horribly, then suddenly will just act like nothing happen, then randomly will happen again... ← Good Evening, I'm fighting the same problem. The ISC (Idle speed control) valve is under the Lexus symbol on the intake manifold. It's a round, black item with several hoses and an electrical connector. Here's the trick: Three of the hoses are coolant lines. You have to remove the wire cover, one large hose from the intake snorkel, and then the coolant lines. The valve itself is a stepping unit. This means you have to apply power to it, then ground two different terminals to move the valve. I'll be pulling mine off this weekend, to check and clean it up. Hopefully, I won't have to buy a new one. If you want, I'll let you know. Good Luck B)
1cardsfan@charter.net Posted February 16, 2010 Posted February 16, 2010 sorry if this is a dumb question, i looked around and couldn't find, where is the IAC located? i assume it's the longer round solenoid on the throttle body (right one)? my car randomly runs horribly, doesn't idle, stalls, will idle very horribly, then suddenly will just act like nothing happen, then randomly will happen again... <{POST_SNAPBACK}> Good Evening, I'm fighting the same problem. The ISC (Idle speed control) valve is under the Lexus symbol on the intake manifold. It's a round, black item with several hoses and an electrical connector. Here's the trick: Three of the hoses are coolant lines. You have to remove the wire cover, one large hose from the intake snorkel, and then the coolant lines. The valve itself is a stepping unit. This means you have to apply power to it, then ground two different terminals to move the valve. I'll be pulling mine off this weekend, to check and clean it up. Hopefully, I won't have to buy a new one. If you want, I'll let you know. Good Luck B) Hi please let me know if it worked for you as Im going to try it on mine also
