Hi
Anyone know where is the axle stand location points for the rear? I wanna change the rear discs. Anyone got any pics of it?
Thanks
Hi
Thanks
You can raise the rear of the car by placing a hydraulic floor jack under the differential and then place your jack stands under the notched out sections of the unibody frame, to the front of the rear wheels. Then let your hydraulic jack down so the car rests on the jack stands. Be sure to chock the front wheels first.
The front jacking point is the frame cross member to the rear of the oil pan. Jack stand locations are just to the rear of the front wheels, again notched out sections on the unibody ridge.
