Hey guys i'm new to the site. I have a 93 sc300. The problem with it is that it has high miles. 170,00. I was wondering if there are any mod's i could put, even with the high milage. Thanks for the help. B)
Like any car out there start with makeing it safe and true,
Check compression in pistons
check plugs wires etc..
change and flush all fluids esp tranny
This will give you an idea as to how the car will last. IE if it has bad piston seals adding a turbo might be a bad waste of $$$.
My car is starting with a new timing belt, shocks struts and springs.
Next will be a breaking up-grade and a up-graded tranny cooler.
All these things will make my car stronger and last (for when the terracharger M90 comes)heh heh .
how far do you want to take your mods? if you just want to do the normal bolt ons like intake, exhaust, ignition and cams then i dont think it will be a problem but like mr.pacoson said you should check out the situation that your car is in before you start to turbo things. and theres always 1000 shot of nos if you really want to break things! :P
