alyoung Posted July 5, 2003 Share Posted July 5, 2003 Hi there, I'm new to this forum and also a new owner of a 94 LS400. I purchased it last week with 69k miles on it. I paid full kbb retail for it but didn't mind since the service history on the car was impeccable. It was a one owner car which had always been serviced pretty much on schedule. The lady who previously owned it did the 60k service at 63k which included a timing belt replacement. The interior looks almost brand spanking new and the exterior is in great shape with just a minor scuff on the rear bumper and some little acceptable knicks. From what I've read, I should be able to get a lot of trouble free driving from this car as long as I keep up with the maintenance on it. I do however have a couple of problems with the vehicle that I just discovered which I hope I can get some help and guidance on from the forum here. 1) The brake light sensor intermittenly comes on indicating that my brakes need to be serviced. I know the brakes are in good shape however, so I'm guessing the sensor is having an issue. 2) The keyless entry does not work. I tried changing the battery on the key and it still doesn't work 3) Lastly, and the most annoying problem, is the driver's side power seat is having a problem. When I try to tilt the back, only the left side tilts. So when I tilt it back, it tilts crooked since only the left side tilts. I've manage to adjust the seat to an acceptable position using the other seat adjustments, but not perfect. Any help, comments, suggestions or direction on how I can go tackling these problems would be a great help. I'd like to get any information I can before I bring it to the dealership and probably end up dropping a bunch of cash just to find out what needs to be done. Thanks!!! Quote Link to comment Share on other sites More sharing options...
VMF Posted July 6, 2003 Share Posted July 6, 2003 i had problem with the sensor and what i figured out is that the cable from the sensor touched the rim while it was moving and of course the cable faced inevitable death, after fixin it and putting a cable tie on it is workin flawlessly for me for the last 1.5 years Quote Link to comment Share on other sites More sharing options...
alyoung Posted July 6, 2003 Author Share Posted July 6, 2003 VMF- Thanks for the info. Did you fix this yourself? If so, how did you go about doing it? Thanks! Quote Link to comment Share on other sites More sharing options...
