dchan865 Posted June 24, 2005 Share Posted June 24, 2005 If the tire is low on air, the GX will alert the driver. It uses some sensor to monitor this. When you rotate the tires, are there anything special you have to do to the tires or rims before or after you do it? My guess is that the sensor is embedded inside the tire or on the rim so one shouldn't have to do anything special and simply swap the tires just like any originally tires. 2nd question: The user manual has special tire rotation instructions dictating how the tires should be rotate. This involves the use of the spare tire. Has anyone did it without the use of the spare tire? Thanks! Quote Link to comment Share on other sites More sharing options...
strindl Posted June 25, 2005 Share Posted June 25, 2005 My Lexus dealer rotated my tires at 5,000 miles. They did not use the spare, and they did nothing but move the 4 tires around. I watched them through the window in the service waiting area. Quote Link to comment Share on other sites More sharing options...
