shonuffking43 Posted June 23, 2005 Share Posted June 23, 2005 :cries: help i am doiing a sludge cleanup and i am down to the oil pan. I have taken off the steel bottom pan and now i can't get the aluminum one off. I have unbolted the pan and it will not budge, the manual says that it should come off but no luck. Does anyone have a clue as to how to get it off. Any help would be appreciated, thanks Quote Link to comment Share on other sites More sharing options...
Toysrme Posted June 23, 2005 Share Posted June 23, 2005 I assume it's a 1mz-fe. There are two bolts that connect the alu. pan to the transmission housing. Make sure you get those off. Quote Link to comment Share on other sites More sharing options...
shonuffking43 Posted June 23, 2005 Author Share Posted June 23, 2005 I assume it's a 1mz-fe. There are two bolts that connect the alu. pan to the transmission housing. Make sure you get those off. ← [/q i did and still am at a quandry, is it just the sealed gasket because it has never been separated since being built, you can see where it's neverbeen broken, theseal ofcourse. Quote Link to comment Share on other sites More sharing options...
