twrenn Posted June 19, 2005 Share Posted June 19, 2005 On my way home tonite I realized that my speedometer needle wasn't showing my speed, it was just sitting on zero. My tach, gas, and temp were all running fine. The previous owner had the gauges sent off to get rebuilt (not sure what that means) so I am thinking it might be a bad connection. Any advise? Quote Link to comment Share on other sites More sharing options...
lovlex Posted June 19, 2005 Share Posted June 19, 2005 mine does that, tap on the dashboard a few times above the speedometer while driving and it should start working, mine does. Quote Link to comment Share on other sites More sharing options...
ED. Posted June 19, 2005 Share Posted June 19, 2005 Thats happened to me in my BMW before but never my Lexus.... thanks Quote Link to comment Share on other sites More sharing options...
CUMan Posted June 19, 2005 Share Posted June 19, 2005 This problem, and it usually involves the tachometer and speedometer, is apparently not related to the common problem of the dash display not lighting when the weather is cool. I think you will find that the needles' failure to move will occur when the weather is hot. As Lovelex stated, a rap on the top of the dash usually brings the needles to life. Sometimes, it takes more than one rap. Quote Link to comment Share on other sites More sharing options...
e2vincent Posted July 18, 2005 Share Posted July 18, 2005 I experienced the same problem, the tachometer and speedometer stay at zero (until you tap on it) when weather is hot. I don't know why a rap is helpful, does it send a electric jolt to the device or loosen the needles a little bit or provides a 'start up' energy to move the needles ? Anyone has a fix on this problem ? Pls share your experience. BR, V. This problem, and it usually involves the tachometer and speedometer, is apparently not related to the common problem of the dash display not lighting when the weather is cool.I think you will find that the needles' failure to move will occur when the weather is hot. As Lovelex stated, a rap on the top of the dash usually brings the needles to life. Sometimes, it takes more than one rap. ← Quote Link to comment Share on other sites More sharing options...
