GPR Posted June 17, 2005 Share Posted June 17, 2005 How does one turn the oil maintenance light of after an oil chane on an ls 430? Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted June 17, 2005 Share Posted June 17, 2005 Your owners manual should give you the answer. B) Quote Link to comment Share on other sites More sharing options...
steviej Posted June 19, 2005 Share Posted June 19, 2005 the owners manual undoubtedly tells you to go to the dealership. GPR, try this technique, it is widely used in many makes of vehicles to reset the maintenance reminder light. 1. Get in the car and put the key in the ignition. 2. Make sure you odometer is in the overall display (not trip A or trip B ). 3. Preset the reset button and hold it in. 4. While holding the button in, turn the key to ON (not START!). 5. Hold the button in for 5 to 10 seconds with the key in the ON position. The Maint. light may flash or may not. 6. Turn the key to OFF. 7. Let go of the button. Now start the car normally and see if the light went out. steviej Quote Link to comment Share on other sites More sharing options...
GPR Posted June 20, 2005 Author Share Posted June 20, 2005 Your owners manual should give you the answer. B) ← Quote Link to comment Share on other sites More sharing options...
GPR Posted June 20, 2005 Author Share Posted June 20, 2005 How does one turn the oil maintenance light of after an oil chane on an ls 430? ← teviej had the answer. Thanks. The owner's manual does not help. :) Quote Link to comment Share on other sites More sharing options...
