How does one turn the oil maintenance light of after an oil chane on an ls 430?
the owners manual undoubtedly tells you to go to the dealership.
GPR, try this technique, it is widely used in many makes of vehicles to reset the maintenance reminder light.
1. Get in the car and put the key in the ignition.
2. Make sure you odometer is in the overall display (not trip A or trip B ).
3. Preset the reset button and hold it in.
4. While holding the button in, turn the key to ON (not START!).
5. Hold the button in for 5 to 10 seconds with the key in the ON position. The Maint. light may flash or may not.
6. Turn the key to OFF.
7. Let go of the button.
Now start the car normally and see if the light went out.
steviej
teviej had the answer. Thanks. The owner's manual does not help. :)
