baudib Posted June 13, 2005 Share Posted June 13, 2005 Hi, I'm new. I had mentioned that I was choosing between a 00 and a 99, but the 00 sold before I could ever get a look at it! I went with the 99 and get the price down to $12,400. also got a pretty good extended warranty (almost everything, $100 deductible, which is nice) for $1,325. After driving low-end GM and Fords most of my life, it is a pleasant change. Smoooooth. So, a couple of questions. How often should I change the oil? 5,000 miles or so? Should I get it done at a Lexus dealership or will a standard Jiffy Lube be OK? What kind of oil is recommended? I assume premium gas is the way to go and the extra $5 or so at the pump seems well worth it. Also, I have no remote. How much will it cost to get one made? Thanks. p.s. Are there a lot of regular posters here? Seems cool to have a community to talk about cars. :D Quote Link to comment Share on other sites More sharing options...
SW03ES Posted June 13, 2005 Share Posted June 13, 2005 Welcome! Lots of regular posters. Congrats on the car! How often should I change the oil? 5,000 miles or so? Should I get it done at a Lexus dealership or will a standard Jiffy Lube be OK? What kind of oil is recommended? 5,000 miles is good, I wouldnt pay the dealer to do it (Mine charges $240 for an oil change) but I wouldn't let Jiffy Lube do it either. I'd find a good independent mechanic to do the work and use Lexus oil filters. I assume premium gas is the way to go and the extra $5 or so at the pump seems well worth it. Thats a point of debate, run a search for premium gas theres lots of discussion about it. Also, I have no remote. How much will it cost to get one made? A lot if you dont get one from here: www.lexus-parts.com Enjoy! Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted June 14, 2005 Share Posted June 14, 2005 I'd consider using synthetic oil personally & yes change it every 5,000 miles. Did you get all service records for the car before you purchased? Best of Luck with your new ride. B) Quote Link to comment Share on other sites More sharing options...
