Rais Up/down Because Of The Ac
Hi ,
I'm facing problem with my AC, when I turn on the AC the engine inceased the rais and down, it happen when you turn on the AC , the rais goes up. and down when the cooling enough. but going up / down so fast ,
like onnn, aaa , onnn, aaaa :)
I took the car to the Air Conditioner thecnician, and he said the coolant fuel is full. I had Cresseda in the past , and had the same issue , and it was only the coolant.
has anyone faced or have sugestion to solve this issue. ?
I'm not quite sure that I understand your post. Do you mean your engine RPM fluctuates up and down constantly?
Do you mean when the engine is cool enough or when the interior is cool enough?
Is this the compressor noise or engine fluctuating noise?
Engine coolant shouldn't have a factor in engine RPM...it could be many things, from faulty compressor clutch, to dirty throttle body, to vacuum leak.
What is your engine temperature by the way?
yes that is the RPM up and down.
I mean the air that comes from the AC, when it become cool , this sound gone,
this issue happen only when turn on the AC, once , then after I increase the RPM, 30 seconeds, it is gone. otherwise I have to start moving to make it gone. and if I stop at any traffic light before 1-2 minutes, it will be the same the RPM will be up and down.
onnn, aaa , onnn, aaaa I feel it only the increase in RPM , up and down.
it happen when the engine is cool or warm, the same.
  • 1 month later...
