flanker271 Posted June 5, 2005 Share Posted June 5, 2005 I know for 2nd and 3rd generation owners here, some have experienced engine die after a long drive on the highway. But for my 92, I have the problem of check engine light lighting up after a long drive on the highway. Autozone said the light indicated code #13. Usually after driving for over 3 hours on the freeway, the check engine light will light up if I slow down to a crawl. If I restart the engine and get back on the freeway, the light will go away. I did this many times and the same results occurs every single time. Any thoughts on this? Could this also be caused by dirty throttle body? Quote Link to comment Share on other sites More sharing options...
mehullica Posted June 5, 2005 Share Posted June 5, 2005 Code 13= crankshaft postion sensor. Quote Link to comment Share on other sites More sharing options...
VBdenny Posted June 7, 2005 Share Posted June 7, 2005 So what does a crankshaft position sensor do? Seems to me if the crankshaft was out of position, the engine wouldn't run? Whatever, it sounds expensive. Quote Link to comment Share on other sites More sharing options...
flanker271 Posted June 7, 2005 Author Share Posted June 7, 2005 I just got my car back from my Toyota dealer. When the previous shop replaced my Timing Belt, they didn't snap the left throttle positioning sensor wire into its slot. So, the timing belt is rubbing against the wire, eating away little by little. This is why I've been getting the light intermediately on and off. It was a $275 fix. $4,788.44 dallors into repair now... Is a Mercedes this expensive to maintain? Quote Link to comment Share on other sites More sharing options...
branshew Posted June 7, 2005 Share Posted June 7, 2005 $4,788.44 dallors into repair now... Is a Mercedes this expensive to maintain? ← Actually a Mercedes is about 2x more expensive to maintain (I know from personal experience). It also helps when you take your car to a good mechanic and not some bonehead that doesn't put the wires back together correctly. Don't forget that you're dealing with a 13 year old car at this point so you can expect some additional maintenance costs as long term parts start to wear out. Quote Link to comment Share on other sites More sharing options...
flanker271 Posted June 7, 2005 Author Share Posted June 7, 2005 Don't forget that you're dealing with a 13 year old car at this point so you can expect some additional maintenance costs as long term parts start to wear out. Yes I'm fully aware of that. This is why I'm still willing to spend $$ into repair in my beloved LS. I'm keeping her for a while :) Quote Link to comment Share on other sites More sharing options...
