If you put custom 18's on a 430 and the techs say they cant use the tire sensor how can you turn the sensor off so it doesnt constantly beep? Can you somehow use this sensor with aftermarket rims?
I have seen plenty of 430's with custom rims so are they driving with the sensor going off or what can you do?
Thanks everyone
Jim
the sensor should fit any rim as it is part of the tire valve on the inside of the rims
lexus should alos be able to disengage the feature with a scan tool
They had me bring my car to the shop because I wanted them to get rid of the chime that came on along with thw low pressure light. I'm not quite sure what they did but the chime and light is now off. They said they were going to disconnect a relay.
