speedyg Posted May 13, 2005 Share Posted May 13, 2005 Does anyone know if ASL can be adjusted or is it simply either on or off? I find that when I get onto the freeway the ASL compensation isn't large enough and I still have to manually increase volume and then decrease it again after I get off the freeway. In my BMW I don't have that problem because it allows you to change the compensation level (I can have the volume go up a lot or change it so that the volume only goes up a little.) Quote Link to comment Share on other sites More sharing options...
thdoan Posted May 13, 2005 Share Posted May 13, 2005 Does anyone know if ASL can be adjusted or is it simply either on or off? I find that when I get onto the freeway the ASL compensation isn't large enough and I still have to manually increase volume and then decrease it again after I get off the freeway. In my BMW I don't have that problem because it allows you to change the compensation level (I can have the volume go up a lot or change it so that the volume only goes up a little.) ← On my RX330, it is just simple on or off. I do not know if it response to the interior noise level, or just to speed of the car. Quote Link to comment Share on other sites More sharing options...
