1992 Airbag Relay Location?
The airbag light is on in my 1992 ES300. Figure the relay is bad, but can't find it anywhere. Where'd they hide this one? Any ideas? Thanks.
Second, after 6 key cycles, the red light on the dash should go off, shouldn't it (all fault codes purge the brain after 6 successful cycles, right?)
BTW, 219K on this one, but runs like rail straight and fast. Boy you can run the wheels off-a these cars!
If you have an airbag light you need to know the code.
If it doesn;t come off you obviously have a problem that needs to be fixed.
A relay for the airbag system? I am not sure what that would even do if you did find one which i don't think it does.
