82DMC12 Posted June 29, 2003 Share Posted June 29, 2003 Hey guys, i think my car has a couple of lights out, maybe you can help. the car is a 94 ES300. 1. the Front Defrost bottom is not backlit but all the buttons to the right of it are. 2. the OFF and Outside Temp buttons are not backlit but the buttons to the right of them are. 3. in my instrument cluster, right where the 3 is on the tach, it is dimmer there than the rest of the console. i assume a bulb is out back there too. first, how do i get to these bulbs? do i have to remove the center console? next, what bulbs do i need? part numbers? Thanks! Andy Quote Link to comment Share on other sites More sharing options...
SKperformance Posted June 29, 2003 Share Posted June 29, 2003 92-96 es 300 to remove the cluster bezel for acess to the bulbs behine the #'s is remove 2 screws behind 2 plastic tabs,that you have to pop off then pull out and disconect the wiring harness for the buttons and the alarm light then it is 4 more screw to then pull out the whole cluster then open the back shroud which has a couple of more screws the lights are part of a twist base with a slot for a flat head screw driver once removed then replaced and reinstall the hvac controler is remove the upper vent above it then 2 screws behind it then under the radio is a plastic tab that pulls forward for to 2 nuts the whole assembly for the radio and hvac is connected together disassemble the 2 by 4 screws and open the hvac front panel and it is little bulbs also that twist off and get replaced in the base holder to be reinstalled the bulbs are avvailable at the dealer change all as it is much simple ad about $3 a bulbs it is easier if you remove everything at once and take it to the dealer to get replacments in another car then reinstall do not turn the car on or drive it while anything is removed or it will cause problem whith the ecu also disconnect the battery the bulbs are supposed to be a 194 of sorts but it varies so be careful that is why it is easier to remove and have them to compare to the new ones Quote Link to comment Share on other sites More sharing options...
Betterthanux5 Posted January 3, 2012 Share Posted January 3, 2012 92-96 es 300 to remove the cluster bezel for acess to the bulbs behine the #'s is remove 2 screws behind 2 plastic tabs,that you have to pop off then pull out and disconect the wiring harness for the buttons and the alarm light then it is 4 more screw to then pull out the whole cluster then open the back shroud which has a couple of more screws the lights are part of a twist base with a slot for a flat head screw driver once removed then replaced and reinstall the hvac controler is remove the upper vent above it then 2 screws behind it then under the radio is a plastic tab that pulls forward for to 2 nuts the whole assembly for the radio and hvac is connected together disassemble the 2 by 4 screws and open the hvac front panel and it is little bulbs also that twist off and get replaced in the base holder to be reinstalled the bulbs are avvailable at the dealer change all as it is much simple ad about $3 a bulbs it is easier if you remove everything at once and take it to the dealer to get replacments in another car then reinstall do not turn the car on or drive it while anything is removed or it will cause problem whith the ecu also disconnect the battery the bulbs are supposed to be a 194 of sorts but it varies so be careful that is why it is easier to remove and have them to compare to the new ones would it be easy to do this but replace them with LED's or would that require like knew wiring and resistors and all that crap? Quote Link to comment Share on other sites More sharing options...
