LexDiamondLS400 Posted April 25, 2005 Share Posted April 25, 2005 Does anyone have the color codes for the radio wiring of 90 ls400?? I wanted to install and aftermarket radio along with component speakers but i dont want to use a wire harness because im not going to use factory speakers amps or radio. Does anyone know how to do this. I believe all i need is the power wire, ignition and remote. But im not sure. thanks for the help in advance. Quote Link to comment Share on other sites More sharing options...
92Lex Posted April 25, 2005 Share Posted April 25, 2005 Just use a harness but remove all the unused pins. Quote Link to comment Share on other sites More sharing options...
Econ Posted April 25, 2005 Share Posted April 25, 2005 If I'm reading my diagram correctly, there's a white wire with a blue stripe that provides up to 20A to the radio, subwoofer and antenna. There's also a gray wire providing a 7.5A source to the radio only - I think this is the remote... (marked ACC in the diagram) Not sure what you're looking for in regards to the ignition wire. It thought the remote signaled when the car was on. Quote Link to comment Share on other sites More sharing options...
LexDiamondLS400 Posted April 26, 2005 Author Share Posted April 26, 2005 If I'm reading my diagram correctly, there's a white wire with a blue stripe that provides up to 20A to the radio, subwoofer and antenna. There's also a gray wire providing a 7.5A source to the radio only - I think this is the remote... (marked ACC in the diagram) Not sure what you're looking for in regards to the ignition wire. It thought the remote signaled when the car was on. ← Thanks alot for the info. Quote Link to comment Share on other sites More sharing options...
LexDiamondLS400 Posted April 26, 2005 Author Share Posted April 26, 2005 Im still having trouble, i didnt any wires that are the colors u described. Please help. Quote Link to comment Share on other sites More sharing options...
Econ Posted April 27, 2005 Share Posted April 27, 2005 Yoikes. That's not good. Ok, there's a harness with the female side closest to the radio that has the white w/blue stripe providing power from a 20A fuse. The grey wire doesn't come from a harness, according to the diagram. Given the difficulty and my inability to expand much beyond what I told you, it might be a good idea just to get a harness and remove the pins you aren't going to use. Quote Link to comment Share on other sites More sharing options...
LexDiamondLS400 Posted April 27, 2005 Author Share Posted April 27, 2005 Problem solved guys thanks alot for the help. Radio is installed and working great. Appreciate the color codes Econ. Thanks again. Quote Link to comment Share on other sites More sharing options...
LexDiamondLS400 Posted May 3, 2005 Author Share Posted May 3, 2005 Just use a harness but remove all the unused pins. ← do you know which wire is for the antenna? Quote Link to comment Share on other sites More sharing options...
LexDiamondLS400 Posted May 3, 2005 Author Share Posted May 3, 2005 If I'm reading my diagram correctly, there's a white wire with a blue stripe that provides up to 20A to the radio, subwoofer and antenna. There's also a gray wire providing a 7.5A source to the radio only - I think this is the remote... (marked ACC in the diagram) Not sure what you're looking for in regards to the ignition wire. It thought the remote signaled when the car was on. ← Do you know which wire is for the antenna? Quote Link to comment Share on other sites More sharing options...
