Instrument Panel Blacks Out - When Warm!
Paul Sherman
Hi all:
A couple of thanks up front.
My heating problem this winter was solved - Two problems
at the same time; a pinhole leak in the reservoir and a defective
coolant sensor. I was low on coolant and didn't know it until I
spotted the empty reservoir.
Also during winter; the infamous no instrument lights until warm,
which changing the capacitors solved.
Couldn't have found those without your help!
Now I have the opposite problem - the instrument cluster
blacks out when the cabin is warm. If I start at a cooler temp, it
stays lit as long as the cart is running. Once I turn it off, then
back on - no display (gas gauge shows empty, etc.). Some
days, when the sun heats the cabin over ~80 degF, the display
never comes on.
Any suggestions?
