Hello,
I have a Lexus SC300 and none of the power switches work for the drivers seat. I have tried the fuses and that has not helped. All 3 movements do not work. Any ideas as to what could be causing it?
Thanks,
Mike
check under the seat, there should be a wire running down under the carpet, if it isn't there then chances are you got one without power seats. I've got the same setup where buttons don't work, I asked around on ALSC and they said it's just a standard production seat.
One way of telling whether it was fitted on your car is to look for two buttons which say 1 & 2, these are the seat memory buttons.
check your owners manual, I'm not sure where they are located for your model.
:ph34r:
