I was washing my 02 ES the other day, and I noticed that my driver door has paint peeling off, right at the bottom of the door. As I touched it, some more paint came off. The paint is peeling off on this rubber strip that's seals the door at the bottom. It shouldn't rust, because it's only the rubber strip on the door, but it's getting noticeable now that you see a black section at the bottom of the door. Does anyone have this same problem? Do you think the warrenty will cover for it? There's no damage to the door or anything...so I didn't hit anything when I was driving.
It is not happening to mine and it should be covered under the corrosion warranty.
Only one way to find out.....ask them.
Hopefully the dealer won't try to say something spilled in that area (aka, brake fluid or some other paint stripping liquid).
steviej
