ryanprun Posted March 18, 2005 Share Posted March 18, 2005 I have a gas smell that I am pretty sure is coming from the front fuel injectors. I was wondering if I just needed to change the 2 seals and gaskets on the injectors or if I should replace the actual injectors also??? Thanks, Ryan Quote Link to comment Share on other sites More sharing options...
NeiLtYmE Posted March 18, 2005 Share Posted March 18, 2005 what kind of gas smell? and how do you know its coming directly from the injectors ?? Quote Link to comment Share on other sites More sharing options...
ryanprun Posted March 18, 2005 Author Share Posted March 18, 2005 the injectors are wet and there is a gas smell in the car and out of it. It is especially strong while idling. Thanks for your response. Quote Link to comment Share on other sites More sharing options...
NeiLtYmE Posted March 19, 2005 Share Posted March 19, 2005 perhaps some bad gas? try a fuel injector cleaner like the Chevron techron stuff. Or even better a Motorvac. that will clean up alot if build up you may have causeing the fuel injectors to choke. Quote Link to comment Share on other sites More sharing options...
