davidk Posted March 9, 2005 Share Posted March 9, 2005 I had my radio worked on. Now the hight light if flashing "normal". The switch on the console has no effect. I'm thinking they may have broken a wire on the switch while removing the radio? Does it sound like I'm on the right track, and how do I remove the panel to check? Thanks Quote Link to comment Share on other sites More sharing options...
SKperformance Posted March 10, 2005 Share Posted March 10, 2005 The switch may not be reconnected. You mean the HEIGHT light right? Quote Link to comment Share on other sites More sharing options...
davidk Posted March 10, 2005 Author Share Posted March 10, 2005 I had my radio worked on. Now the hight light if flashing "normal". The switch on the console has no effect. I'm thinking they may have broken a wire on the switch while removing the radio? Does it sound like I'm on the right track, and how do I remove the panel to check?Thanks ← Yes, I meant the HIEGHT light. Did you mean the switch "May not have been reconected" or "It can't be reconnected"? Thanks, Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted March 11, 2005 Share Posted March 11, 2005 Exactly who worked on the radio? "Lexus" dealer? I would take it back to them to check. I am guessing something was disconnected by mistake. I had my radio worked on. Now the hight light if flashing "normal". The switch on the console has no effect. I'm thinking they may have broken a wire on the switch while removing the radio? Does it sound like I'm on the right track, and how do I remove the panel to check?Thanks ← Yes, I meant the HIEGHT light. Did you mean the switch "May not have been reconected" or "It can't be reconnected"? Thanks, ← Quote Link to comment Share on other sites More sharing options...
davidk Posted March 22, 2005 Author Share Posted March 22, 2005 I had my radio worked on. Now the hight light if flashing "normal". The switch on the console has no effect. I'm thinking they may have broken a wire on the switch while removing the radio? Does it sound like I'm on the right track, and how do I remove the panel to check?Thanks ← Boy is my face red! The problem was the Air Suspension switch in the tool kit bay was in the off position. Quote Link to comment Share on other sites More sharing options...
