fishyboy1 Posted March 9, 2005 Share Posted March 9, 2005 Code 21 Code 28 I tried doing a search here for this but it won't let me search for the numbers, it says the words are too short. ANYWAY........... I found the chart that shows what the codes mean, but my question is would this cause the car to run weird like it is or could that be something else?????????? For those who didn't see my other post, it's running ok but seems to have weird idle issues. When driving down the road and I let off the gas the RPMs jump up and down. That's the easiest way to explain it. Thanks Quote Link to comment Share on other sites More sharing options...
hangloose4 Posted March 10, 2005 Share Posted March 10, 2005 i had this same problem with my 1992 es 300. it ended up being the throttle body, it was first cleaned, and finally just replaced. so i'm not sure what the codes meant, but after the throttle body was replaced the problem went away. by the way, do you have any idea what i need to do to replace my rear wheel bearings? Quote Link to comment Share on other sites More sharing options...
