Switching My Radio.
Hey I have a 93 GS300, and I was sort of wanting a new faceplate deal or whatever you call the radio up front. i wanted to swap out that one with like one from an IS300 or from a newer GS. is it possible to switch those out like that as long as i get it to fit?
The harness is not the same nor is the the angles on the radio. You'd be better off buying a kit and an aftermarket radio as it will look much better. If you do try the IS300 radio you'll need to get a reverse harness to plug into the IS300 radio and wire it to the GS harness. <_<
