vineetag Posted February 21, 2005 Share Posted February 21, 2005 Although my 97 LS 400 (185K miles) seems to ride fine, when I try to put the car into Park, the gear locks out in Neutral. I have to turn the engine off to put it in Park. The dealership said the Neutral Lock switch was bad and would charge $700 to replace. They also told me to push the bypass switch in the gear panel until I can get the switch replaced. Also, my check engine light has been coming intermittently for a couple of weeks, so I took the car to another local mechanic. He told me that the engine was 'unstable', and refused to work on it. He said it could be the linkages, or the motor, or a few other jargon things I didn't follow... Any suggestions? thanks, Quote Link to comment Share on other sites More sharing options...
blake918 Posted February 21, 2005 Share Posted February 21, 2005 I'd swing by a local AutoZone and have them read the check engine light and post the code on here. 185k is childs play on a LS400; the mechanic probably got scared off by the mileage and the extra troubles it might entail. Quote Link to comment Share on other sites More sharing options...
blake918 Posted February 21, 2005 Share Posted February 21, 2005 Please delete. Quote Link to comment Share on other sites More sharing options...
Watisgood Posted February 22, 2005 Share Posted February 22, 2005 i have a 90 ls 400 180,000mi and the check engine like was coming on the cause wat the 2 main oxygen sensors. Quote Link to comment Share on other sites More sharing options...
