jnelson Posted February 17, 2005 Share Posted February 17, 2005 I have a 95 SC400 with a slight whine coming from the transmission. You can clearly hear each shift, both up and down. If it were a manual with 143k I would say it was fine, but of course it's an auto. Is this normal? The other noise: starts at about 40 mph and seems to increase with speed. Sounds like it's outside, you can hear it well if driving near a wall. Tried coasting at speed, noise still there. Quote Link to comment Share on other sites More sharing options...
brucelee Posted February 17, 2005 Share Posted February 17, 2005 The trans does have an inherent while in it. Can't tell without hearing it if it is abnormal. It is a good idea to do a trans service on it anyway, no? Re: other noise, sounds like a rear diff is dying. Does it get worse as you back off the car at speeds? I have a 95 SC400 with a slight whine coming from the transmission. You can clearly hear each shift, both up and down. If it were a manual with 143k I would say it was fine, but of course it's an auto. Is this normal?The other noise: starts at about 40 mph and seems to increase with speed. Sounds like it's outside, you can hear it well if driving near a wall. Tried coasting at speed, noise still there. ← Quote Link to comment Share on other sites More sharing options...
