I have a 94 ES300 and the dome light has burned out need help in how to remove the cover without breaking it. Just didn't want to use to much force. What parts come off and do you just pry it off. Thanks
the dome light cover just pops right out.... you can use something like a flat head screwdriver as leverage
  • 5 years later...
I wonder if this applies to the front dome light, which is next to the sunroof buttons. I can see clips on the rear one, but not on the front one. In the front dome light area, I can also see or make little between the plastic frame and the roof. Now should I remove the whole assembly with the plastic frame or just the light cover? Thank you.
