My 1999 RX 300 has over 75,000 miles on it. I was wondering if any of my fellow RX300 owners out there are aware of any known defects coming up that I should be aware of ??
Try doing a search first on this forum to find the information your looking for. B)
:cheers:
I have 80,000 and nothing yet, I think my front strut bushings or somethign like that are going out, but there is a TSB out for them or so i read on here. That should replace them.
Change your fluids: coolant, brake fluid, transmission fluid, power steering fluid with genuine Toyota fluids which are the same as the factory fill fluids. Also consider changing your spark plugs, spark plug wires and engine cooling system thermostat and scrub the throttle plate clean of deposits with a toothbrush, some old rags and carburetor cleaner - if you want optimum power and fuel economy.
