My 95 Lexus Es300 Has Some Problems
Bender
The antenna wont go down.
The trunk release button doesnt work.
Interior lights dont work.
The passenger door handle inside and outside wont let the door open.
Glove compartment light doesnt work.
The key has a hard time fitting in the trunk keyhole.
Is this a simple fuse related problem?
Any ideas or advice will be greatly appreciated.
Thank You, Bender
every problem is not related to anyother ones
does the mast make any noise when turning the radio on or off?
the trunk lockout button is in the glove box press it to make the button on the door work again
you need to open the door and reattch the rod to the door lock
chaneg the bulb in the glovebox
spray wd40 in the key lock to loosen it
THANKS FOR THE REPLY. HERE ARE MY ANSWERS. BENDER
does the mast make any noise when turning the radio on or off? YES
the trunk lockout button is in the glove box press it to make the button on the door work again. OK I WILL LOOK FOR IT
you need to open the door and reattch the rod to the door lock. I CANT OPEN THE DOOR AT ALL
chaneg the bulb in the glovebox. OK
spray wd40 in the key lock to loosen it. OK
Need to find a wayu to open the door to remove the inside door card to acess the internals, if you don't have the expertise i guess you will need to get a technitino to repair it.
If the ant makes noise but doesn't move,read the FAQ and replace the mast
  • 1 year later...
:cheers:
Thanks Bender for the tip on the trunk lockout button. I was cleaning my car and must have accidently pushed on that button.
Cheers.
GuruBaba
