mysticwar Posted June 16, 2003 Share Posted June 16, 2003 The inside of both headlights are so foggy & cloudy. How can I clean them? Quote Link to comment Share on other sites More sharing options...
bbsal Posted June 16, 2003 Share Posted June 16, 2003 i posted about this before.i will attach the file so you can read how to do it.you will have to heat the whole light and pry it open to clean them. index.htm Quote Link to comment Share on other sites More sharing options...
stevenh Posted June 18, 2003 Share Posted June 18, 2003 I had tremendous success cleaning the foggy lenses on my 1992 ES 300 by using 3M's "Plastic Cleaner" (39017) and "Plastic Polish" (39010). I baked my entire headlight in the oven, pried the unit apart, and so on, but I found that most of the problem was on the outside of the lenses. Thank goodness! I did, however, take the opportunity to repair a torn bit of rubber gasket that may or may not have been letting in moisture, and I did wipe some sort of film off the globes that cover the low- and high-beam bulbs. But really, I'd start with the products named above and see if you're satisfied. You might save yourself considerable time and effort. Quote Link to comment Share on other sites More sharing options...
bbsal Posted June 19, 2003 Share Posted June 19, 2003 i used that plastic polish on mine and it does work wonders.i recommend trying that also. Quote Link to comment Share on other sites More sharing options...
bbsal Posted June 19, 2003 Share Posted June 19, 2003 one thing though.after taking apart the light i wouldnt rub the inside of the cover too much because it gives scratches.most of the problem is on the front of the light and also the film on the projectors that you can easly clean with soap and water.there just a big chunk of glass.. Quote Link to comment Share on other sites More sharing options...
bbsal Posted June 19, 2003 Share Posted June 19, 2003 also like i always say TAKE YOUR TIME PRYING AT IT BECAUSE YOU DONT WANT TO BREAK ANYTHING.IT WILL COST ALOT IF YOU RUSH SO JUST TAKE YOUR TIME AND YOU WILL BE FINE.it really easy for the front lights.but if you plan to clear the back ones then be even more carfull because they are more delicate. Quote Link to comment Share on other sites More sharing options...
