What Is The Problem?
cenwesi
Ok on about 3 times now i am driving and i am about to stop at a light and the car cuts off. I put it on park and start it again and it starts and no problem anymore. I recall this happening one time before my starter died? Is this the sympton again or is this something having to do with the fuel?
could be a number of things, as simple as a broken vaccum hose, to something more major like a bad MAF or even ECU ect..... as the symptons you are stating are common to a lot of different problem areas.
do you have the check engine light on?
i would just take it to your trusty mechanic and have him diagnose the problem, most good ones will give you a diagnostic for free.......
then once he tells you the problem go from there ie......get the part yourself online (most of the time cheaper), and DIY
