wagsy22 Posted January 4, 2005 Share Posted January 4, 2005 I need to replace my front rotors because of warping - but I checked some online web sites for parts and the front rotors are $120/each. Napa and Autozone have them at a fraction of the cost like around 30 bucks. I have been told that the lexus brake pads are the best around for a gs400 so I dont think I will deviate there, but are the rotors that much different? Tell me why I should by Lexus parts here???? Wagsy Quote Link to comment Share on other sites More sharing options...
TurboGS300 Posted January 4, 2005 Share Posted January 4, 2005 I don't think you should <_< You can get a good set of (4) drilled and slotted rotors for around $130 and up. B) Quote Link to comment Share on other sites More sharing options...
Steve@Lextasy.com Posted January 4, 2005 Share Posted January 4, 2005 I don't think you should <_< You can get a good set of (4) drilled and slotted rotors for around $130 and up. B) ← http://www.lextasy.com/cross_drilled_slott...s_1131_prd1.htm Quote Link to comment Share on other sites More sharing options...
wagsy22 Posted January 4, 2005 Author Share Posted January 4, 2005 I don't think you should <_< You can get a good set of (4) drilled and slotted rotors for around $130 and up. B) ← http://www.lextasy.com/cross_drilled_slott...s_1131_prd1.htm ← Steve - those look good - it shows all four which I assume is the front and rear, can you confirm - 4 for $255? Also, are the holes drilled in the rotor after it has been manufactured or are the holes cast in the rotor during manufacturing? I have heard about stress fractures developing (from excess heat) on slotted/drilled rotors where the holes are drilled. Please confirm Thanks, Wagsy Quote Link to comment Share on other sites More sharing options...
DENN!S Posted January 4, 2005 Share Posted January 4, 2005 I am also interested in these, can you confirm the manufacturing process. i.e. drilled after casting or casted holes... thnx Quote Link to comment Share on other sites More sharing options...
