wing0 Posted December 21, 2004 Share Posted December 21, 2004 2001 RX300 13k miles Notice noise from the front belt. I think it's pretty close to the bumper right? I can hear belt noise when i'm standing infront of the hood. In the cabin, with everything off ie. no air and music. A ticking noise can be heard, even after car warms up. It's winter in Canada, so around -5C. The noise interval is constant and is coming from the hood when in cabin. Even turning air to around 3 bars, i can still hear the ticking noise. While stepping on the gas, engine is noticeably noisier, sounds a little like diesel engine in comparison with noise during summer. Finally, the noise seems to be toward the front passenger's end. Just had service in the summer, everything checked out ok. Also, rear hatch opens half way, then stops. Have to push it up fully, hope lexus agree that it has problem and replace the shock thing. What could be the problem? Should I take it to Lexus and have them listen to the sound? and drive one of their used RX300 for comparison? Thanks for reading and feedback is appreciated! Merry Christmas! Quote Link to comment Share on other sites More sharing options...
ColinBarber Posted December 21, 2004 Share Posted December 21, 2004 Ticking noise could be injectors, a drive belt or even valve clearance although shouldn't be at that mileage. I would let your dealer take a look, it is still under warranty isn't it? I just had my rear hatch struts replaced, when new they seem only just strong enough to open so as they get older and lose pressure you get the problems you have. You should be able to get them replaced under warranty. Quote Link to comment Share on other sites More sharing options...
Russ White Posted December 21, 2004 Share Posted December 21, 2004 Just to be safe, check your engine oil level. A damaged filer, filter gasket, loose drain plug, etc. might result in low oil, low oil pressure, and valve noise. Please do this before you drive it even to the dealer. Russ Quote Link to comment Share on other sites More sharing options...
Hub Posted December 22, 2004 Share Posted December 22, 2004 I aksed my Lexus dealer about that noise and was told that it is from the fuel injectors and is a normal noise. My wife thinks that's crazy. Quote Link to comment Share on other sites More sharing options...
wing0 Posted December 22, 2004 Author Share Posted December 22, 2004 fuel injector noise? uh...why doesn't this sound come when u first bought the car?? don't tell me it's because the injector is getting old. lol...i'm still bringing it in for the rear hatch and see what they say about this. if this is the noise that the fuel injector is making and it's loud enough to go through the insulation(while u merely hear your engine sound) then i gotta say there's something wrong with the injector. Quote Link to comment Share on other sites More sharing options...
