arthurstrang Posted December 14, 2004 Share Posted December 14, 2004 My 2000 ES300: The right vent of the two central vents in dash emits 10 degree colder air to passenger than the left (central vent)!. I know each vent has a common source. Perhaps the air flow is laminar: is an air mixing device failed? Seems more pronounced as car gets older. (Lexus replaced air conditioner filters, cleaned sensor under steering wheel, and checked AC fluid.) Any ideas? Quote Link to comment Share on other sites More sharing options...
jlmoreno911 Posted December 14, 2004 Share Posted December 14, 2004 I beleive most cars will do that, the air has to travel farther to the drivers side which by the time it gets there it isn't as cold...but 10 degrees is a little high...also something on the driverside could be emiting heat and causing it... Quote Link to comment Share on other sites More sharing options...
arthurstrang Posted December 15, 2004 Author Share Posted December 15, 2004 My 2000 ES300: two central vents in dash emit 10 degree colder air to passenger than to driver. I know each vent has a common source. Perhaps the air flow is laminar: is an air mixing device failed? Seems more pronounced as car gets older. (Lexus replaced air conditioner filters, cleaned sensor under steering wheel, and checked AC fluid.) Any ideas? ← Quote Link to comment Share on other sites More sharing options...
arthurstrang Posted December 15, 2004 Author Share Posted December 15, 2004 I beleive most cars will do that, the air has to travel farther to the drivers side which by the time it gets there it isn't as cold...but 10 degrees is a little high...also something on the driverside could be emiting heat and causing it... ← I have corrected my post: it is the right vent of the two central vents that emits air 10 degrees colder. (I can both feel it and measure the difference.) Quote Link to comment Share on other sites More sharing options...
