EnDLesS Posted November 29, 2004 Posted November 29, 2004 Does anyone know how to reprogrammed from the old factory remote to new one?
dougjohn2 Posted November 30, 2004 Posted November 30, 2004 EnDLesS! I expected better from you... ;) I searched ih8mud using "program" and "alarm" as keywords and found the following link in one of the threads: http://www.sleeoffroad.com/technical/tz_alarm_manual.htm You can download the manuals you need...or all, if you like. Cheers.
EnDLesS Posted November 30, 2004 Author Posted November 30, 2004 Thanks Dougjohn2: I went to Lex dealer today to reprogrammed your stock/factory remote turned out to be by pressing remote and adjusting (philip screw driver) right under driver seat ( black box - Alarm brain) damn cost $ 82.00 buks for that <_< :(
dougjohn2 Posted November 30, 2004 Posted November 30, 2004 you're kidding!!! they charged $82 for it? ...and you paid?
Summer Posted April 6, 2005 Posted April 6, 2005 Thanks Dougjohn2:I went to Lex dealer today to reprogrammed your stock/factory remote turned out to be by pressing remote and adjusting (philip screw driver) right under driver seat ( black box - Alarm brain) damn cost $ 82.00 buks for that <_< :( ← I recently purchased a LX 450 and the remote will not work. I replaced the battery and still nothing. The only thing that happens is the led on the remote flashes rapidly. Do you have any idea of what may be wrong?
Rookie Posted April 15, 2005 Posted April 15, 2005 I recently purchased a LX 450 and the remote will not work. I replaced the battery and still nothing. The only thing that happens is the led on the remote flashes rapidly. Do you have any idea of what may be wrong? ← Try opening it up and see if you're getting good contact between the tab and the battery. The tab over time starts to loose contact. You can bend it a little, and that might solve you're problem. Otherwise, you might be able to pick up one on ebay of $25 bucks or so and reprogram it. Rookie
dougjohn2 Posted April 15, 2005 Posted April 15, 2005 I wonder if it's ever worked for you? Has it? If Rookie's suggestion doesn't work, you might try to reprogram it. You can find instructions on how to reprogram your remote on the tech section of the www.sleeoffroad.com web site.
Summer Posted April 15, 2005 Posted April 15, 2005 I wonder if it's ever worked for you? Has it? If Rookie's suggestion doesn't work, you might try to reprogram it. You can find instructions on how to reprogram your remote on the tech section of the www.sleeoffroad.com web site. ← I HAVE ONLY HAD THE TRUCK A MONTH OR SO AND IT NEVER WORK BUT I WILL TRY BOTH OF THE SUGGESTIONS. THANKS
