chris17house Posted November 12, 2004 Share Posted November 12, 2004 Well its been a while now and ive finally gotten sick of pressing the spring down on the drivers side control panel to lock my doors haha. The clamps that the original button is supposed to snap into have just worn away over the years i guess. Does anyone know a good way to fix the broken plastic clamps? If not, if i get the replacement part, is this a project that i can get into trouble with? Thanks a lot Chris Quote Link to comment Share on other sites More sharing options...
jlmoreno911 Posted November 12, 2004 Share Posted November 12, 2004 Mine did the same thing...just broke a couple of weeks ago. I took the spring out and just press the "button" to lock the doors... Let me know if you find a replacement if they are cheap I want to get on too... Quote Link to comment Share on other sites More sharing options...
jahon Posted November 12, 2004 Share Posted November 12, 2004 you might be able to put it back together by using apoxy glue. Quote Link to comment Share on other sites More sharing options...
gbhrps Posted November 12, 2004 Share Posted November 12, 2004 I'm not certain that I understand what spring everyone is talking about, but I assume its the interior power door lock switch. If I'm correct about that, its not a big deal to wrap a screw driver with tape (to prevent scratching the panels) and pop out the entire panel with all of the power window switches in it. The switch itself can be unplugged from its wiring harness and the switch removed from the panel. Just order a new switch from Lexus, or take the old switch to a junk yard where they'll allow you to wander and check the wrecks for the parts you want. Many of the Toyota cars use switches from the same parts bin and you should be able to find a replacement pretty easily. Quote Link to comment Share on other sites More sharing options...
chris17house Posted November 13, 2004 Author Share Posted November 13, 2004 I'm not certain that I understand what spring everyone is talking about, but I assume its the interior power door lock switch. If I'm correct about that, its not a big deal to wrap a screw driver with tape (to prevent scratching the panels) and pop out the entire panel with all of the power window switches in it. The switch itself can be unplugged from its wiring harness and the switch removed from the panel. Just order a new switch from Lexus, or take the old switch to a junk yard where they'll allow you to wander and check the wrecks for the parts you want. Many of the Toyota cars use switches from the same parts bin and you should be able to find a replacement pretty easily. ← I dont think the wood panel covering the switches comes off like that. i think i need to take the door panel off, but im not sure if a bunch of stuff is gonna fall out of place if i do this. Yeah i have the replacement part, ebay usually has about 2 or 3 every other week if you look a little. Quote Link to comment Share on other sites More sharing options...
